i am buying b18c7 jdm motor but not sure what year this motor cam on itr .is it for 2dr or 4dr,obd1 or obd2. do u guys have any ideas?thanks.
well i just learned that they made a C4, maybe who knows, they might have made a C7 or else you are just getting screwed, Good Luck
ive never heard of anything over a c5 either.. but if it really does exist my guess would be that is obd2
the C6 and C7 are both from the 96 spec type R ... im guessing one is Euro spec and one is Japan spec or somethin like that ... but it is from a 96 type r
U.K. and Euro-spec. cars use the B18C6 version of the 1797cc engine: US-spec motors are designated as the B18C5, and the Australians use a B18C7 on their ITRs. JDM 98specRs simply have "B18C" as the motor designation.
so its Aust. spec. motor thanks Slohonda. Do have any idea what kind of octaine is required for Australian itr. do they use leaded or unleaded fuel.thanks again.
it is still a honda engine with a high c/r fill it with super if you can afford it if not 89 will be fine unleaded
i am in Jordan 90% of vehicles use lead fuel .we have very few gas stations that offer unleaded but octaine is 87 RON at best.this itr motor is realy cheap $400 .
$400 is incredible for an R motor. 87 is not so good. I don't know if the R motor will blow itself up on that or not.
now i have jdm b18c(gsr) with lsd in my 96 ex coupe on hot day 35 degrees C. the engine knocks 90 degrees F.
Then I would say the R motor will knock as well, I don't know the compression in the C7 but if it is the same as the C5 it won't handle 87 octane on a hot day.
anyone from down under here? wow 400 for a type R. Are all the engines overthere that cheap (is it american dollars) damn you could buy my enigne then send it here to the states
