Type-r? Or Prelude ?
Discussion in 'HYBRID -> EG-EK / DC' started by ICEMAN13, Mar 13, 2003.
  1. ICEMAN13
    ICEMAN13 Junior Member
    :blink: I dont know which way to go I want a beast to run on the streets but I dont know exactly what engine to drop into a Civic Hatchback. I know that for direct performance go for the Type - R but I also know that if you work on a H22a it will run like the devil himself. So if you have any advice to give please hit me back aight
    ----thanks
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    moving to what should i swap
    and get an itr
  3. shuturmowth
    shuturmowth Senior Member
    cali
    man it depends on your budget , dont be soo vague.... but i agree with pills get the itr if you can afford it.... :blink:
  4. preluderjs
    preluderjs Senior Member
    san diego
    Why? I just want to know what this is based on. I didnt think it made a difference for a daily driver, but I havent really given it much thought, so ummm.... yea, ignore that.
  5. monzee
    monzee Member
    Singapore
    B18C jdm specs engine with Toda or JUN stage 3 cams,oversize 81.25mm ITR pistons, chipped up ECU to match.
    Or B16head with a B20B block, high dome pistons of 85mm, chipped up ecu to match.
  6. 2 litre EG
    2 litre EG Senior Member
    so cali
    personally if you have the money stick with the B18C spec R [type r motor]... you'll make damn good power if your going all motor
    with the type r motor you wont have to worry about understeer or anything like that... also you will be able to REV higher, and you'll have a damn good tranny [one that im looking for at the moment :p ]
