Type R Question
Discussion in 'HYBRID -> EG-EK / DC' started by Typie, Aug 20, 2006.
  1. Typie
    Typie New Member
    im buying a 2001 acura integra type r but i have a few concerns about one im buying. its got a b18c1 bottom with a type r head...im sure the b18c1 is from a gs-r engine and not the stock type r bottom. is this a good thing or a bad thing? - any reason why it would have a gs-r bottom instead of the stock type r bottom? or is it the same thing. has the car lost hp or gained or is it the same?
  2. d.b.cooper
    d.b.cooper Mid-life Crisis Swap
    Phoenix Metro Area
    I think Type R had higher compression pistons than GSR?
    If so, that would mean less HP. 10-15?
  3. Typie
    Typie New Member
    that sux...so then its not a type r anymore....its almost back to gs-r hp...wtf was the point in that why would he change the bottom for less hp. anyway thanks cooper. can anyone conferm this?
  4. EG6Civic83
    EG6Civic83 New Member
    Type-R/ GSR Motor Differences (Some)
    are you sure the car is an actual Type-R? the guy may be selling it for a Type-R price when its really just a GS-R with a new head. im not trying to say the guy you are dealing with is shady or anything but if you have these kinds of concerns it may not hurt to ask yourself (and him for that matter) these kinds of questions.
    the comp ratio of a B18C5 teggy r is 10:2:1 and the comp for the B18C1 is 10:0:1. the GS-R is supposed to have around 170 hp while the R is around 195 i believe. a GSR with the lower comp ratio may give more torque in the lower end (maybe??) while still reving like an R. all in all it's not a bad set up but be wary of the guy if he's saying one thing but the motor tells a different story.
  5. Typie
    Typie New Member
    yeah thats true, im just gunna go with the other type r i was chosing from. the first type r is a 2001 with only 50,000 km but has that gsr bottom, paint has a lil scratch on fender thats it. the other one is a 1999 type r with 100,000 on it but is a true type r with full type r motor (c5) and im getting them for basicly the same price. i say go with the 1999, what do u guys think?
  6. daf
    daf Junior Member
    From what I understand, the biggest issue between the GSR and ITR engine is the ITR has a mild P&P on the head. I also know the ITR crankshaft is a bit better as far as handling stress.
  7. Typie
    Typie New Member
    yeah sounds right....most likly going for the true typie, b18c5
  8. greygoose
    greygoose Junior Member
    The only difference between a type-r and a gsr is the head , pistons, intake manifold, throttle body, header, and tranny that has lsd. Correct me if I'm missing anything. Now if you have the head then you the best part far as the bottom end goes just put some type-r pistons in it an call it a day. But if they want to charge type-r money than don't get.
  9. Spyderturbo
    Spyderturbo Senior Member
    PA
    this is true, the main difference is the head and intake manifold, the ITR has a single runner setup like the B16, therefore it makes all the power up high, the GSR has a dual runner intake manifold with butterflies in it, similar to the older H23 manifolds. The ITR head is hand ported at the factory and I could be wrong but I'm thinking the ITR pistons are forged vs. the vacuum cast slugs in the GSR's. The ITR also has a different suspension, extra bracing, and a pimp interior with recaro's. I know I miss my 2000 ITR....
  10. EG6Civic83
    Honda made factory OEM forged pistons??????? Thats a new one on me.
  11. formby
    formby learning in progress
  12. Spyderturbo
    PA
    I only owned mine for 6 months so my bad, you are correct, they were not forged but they are indeed different from a GSR, as are the rods and the assembly practices. Here is a link to some info I found.
    Specifications and Technical Information - Acura Integra Type R
  13. EG6Civic83
    Yeah I was thinking all of Honda's OEM pistons were cast.
