Type R Swap
Discussion in 'HYBRID -> EG-EK / DC' started by turbodx, Feb 11, 2003.
  1. turbodx
    turbodx Junior Member
    What parts do I need to complete this swap.
    I'm getting everything except the shift linkage and the axels :ph34r:
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    It's the same as any other B series motor,and you need the shiftlinkage and axles.
  3. kyleirwin
    kyleirwin Retired OG
    Vegas
    you'll need to convert to obd2. add a 4 wire o2 sensor if you've got a cx or vx model. add wires for vtec and the obd conversion. and 92b16vx is right, you're gonna need the shift linkage as well as the axles.
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Instead of converting it to OBD2, you can run a chiped OBD1 ECU and stock wiring harnesses.
  5. ALLJDM
    ALLJDM Senior Member
    Tampa, FLorida
    ditto!
  6. pissedoffsol
    jdm integra type R's are PLUGGED for obd2, but are really still obd1
  7. asmallsol
    Meaning what?
    (kinda dont follow)
    To get that thing in i dont know a 95 sol si (frost white of course) Do i just use my stock wire harnesses and a Chiped ecu?
  8. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    TURBODX, I love it when I hear people going with an R-spec motor. Post some pics when you're done. Good luck.
