TypeR head or not?
Discussion in 'Civic and del Sol - EG and EK' started by Dannyum89, Nov 28, 2008.
  1. Dannyum89
    Dannyum89 New Member
    Hollywood
    Hey guys. Im brand new to this forum but not new to forums so please dont treat me like a newbie. I recently bought a 92 civic hatch from a friend of a friend. Gas prices were too high for my T/A. From what I gather it has a B18c1 with a 00 Si tranny. Its got a whole bunch of other bells and whistles but for the most part this could be called a GSR swap rite? Anyways my question is the head has the stampings 99 PR3-3. I did some homework and found out this is a B16 head and could be aTypeR head correct? I read that if it was a TypeR it would have dual valve springs. Problem is I cant see in there. I see the springs but cant see if theres another smaller one in the middle there. I dont see the green mark either. Can you tell by the cams without a micrometer? I posted this in the wrong thread earlier. sorry. Any help would be appreciated.
  2. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    probably a b16 head from a 00 civic si. type r head has green paint on it.
    some people build a poor mans type r using a b16 head on a gsr block.
  3. Dannyum89
    Hollywood
    Just picked up the head from the machine shop to have it shaved before I replace the head gasket and the guy there told me its a B16a head with what he thinks are typeR cams. Thats good I guess rite?
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    As good as any.
  5. efhondakid
    Akron-Canton, Ohio
    You tell by markings on the end of the cam where the dizzy goes in at, but I cant remember what they look like or where I found the info. Ill try to find it for you.
  6. xj0hnx
    C.C.TX.
    I posted pics a WHILE back on here when I swapped my cams, but can't find them :(
  7. Dannyum89
    Hollywood
    Theres markings on the end of the cams. They look hand engraved. CR/ 253-0012E and 253-27-05 if thats any help.
  8. Dannyum89
    Hollywood
    No one knows what these numbers mean???
  9. eg6sir
    cams can be swapped.. cant tell from that.... if it were a type r head it'd have a factory port job
  10. efhondakid
    Akron-Canton, Ohio
    :werd: Only difference between a Type-R and a regular B16 is dual valve springs more aggresive cams and a factory P&P job.
