i know uberdata is fuel managment but what does it do and is it any good,i plan on boosting my d16z6,and i heard of a lot of ppl who use it,and where can i get 1?
uberdata is a software package that lets you burn/create chips that you can insert into your socketed obd1 ecu. you can tune you rcar with them by setting your own fuel and ignition maps, vtec engagement point, etc etc..
on a boosted car, it is beneficial, because it allows the computer to actually READ boost (up to 11 psi of the stock map, or 27psi with a GM 3-bar map) and thus create fuel and ignition maps for POSITIVE vacuum, or boost, on the map sensor.
