uh oh, finished swap, is leaking oil bad?
Discussion in 'HYBRID -> EG-EK / DC' started by deity, Oct 25, 2005.
  1. deity
    deity Junior Member
    ok so i have my gsr swap done and running but a slight issue. where my shift linkage connects to the shifter fork on the tranny is slowly dripping oil. i have the technical know-how to swap motors, and pull the tranny if need be but is there a seal that prevents this? maybe that rod is bent? im really freaking out, i paid alot for this trans,
  2. deity
    deity Junior Member
    im thinking its seal number 21. i wonder why its leaking though.
  3. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    dunno? try replacing the seal, couldn't hurt.
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    :werd: I don't think it could be anything else... [​IMG]
  5. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Go with that ^.. my z6 was leaking all over from there, and the case, and the axles.... so i just put cardboard down :)
    That one looks easy to fix up.
    Good luck
