hey guys this is my first post on here. im from the uk and wanting to build a turbo b18 motor to put into my 97 civic coupe, iv been searchin on here about this but not found anything speacif to my build
basically im looking to build a street b18 turbo, its going to be my daily drive and looking for 300-400 bhp, im going to re-sleave the block, but not sure which pistons,rods,head bolts to use and im not sure about the whole compression thing if someone could explain this?
also would i need a different type of head gasket maybe a thicker one or stronger one?
and if i build the bottom end up would i need to uprate the cam shafts or can i use standard.
any help would be much appeciated
