underbody neon light install
Discussion in 'ECU's, Electronics, and Tuning' started by x007den, Aug 1, 2003.
  1. x007den
    x007den Junior Member
    i just got a couple of 18" underbody neon light tubes for my ride. im pretty good with body work but i have no idea how to wire these suckers. all i know is that the tubes each have a built in transformer and the black and red wire coming out of it. i want to be able to have them on without my headlighs having to be on, if not possible its ok, i also want to have a switch for them in the dash, what am i going to need to get and what should i do??
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    black is ground red is 12v pos wire them up
  3. BigJ
    Go buy some switches at the local shmucks and a lot of good 16 guage power wires. Run the wires from like a direct power from your battery to the switch in your dash, then seperate them with splicing/other ways/etc into the neons. This is like the most simple thing since you don't even want it on accesory.
  4. x007den
    what would i have to do if i wanted them on at acc?
  5. hcivic.com
    grab a wiring diagram and go to it
  6. x007den
    alright thanks
  7. hcivic.com
    you will need to fine the acc wire and aire up the lights to that
  8. x007den
    one last question, im really not familiar with switches so i am assuming that i am going to get 16 gauge wire hook it up to the pos. battery. then ill connect it to the switch. then i think i will connect a new red wire somewhere on the switch that will be spliced to reach my two tubes. is that the set up?
  9. hcivic.com
  10. tedwright
    tedwright Senior Member
    UPSTATE NY
    STOP RIGHT THERE.
    if you are "really not familiar with switches", then DO NOT TOUCH YOUR CAR!
    :asshat:
  11. x007den
    thnaks for all the help, seems pretty simple now.
  12. IDMaxGuy
    IDMaxGuy Senior Member
    MO
    Didnt it come with instructions? Red Pos Black Neg.
