Im unsure as to what spark plugs would be recommended for my setup. I have a 91 civic with a b18a1 swap. I have an MSD Pro Billet Distributor & all the recommended parts. Plus I have an MSD SCI-L Ignition Box aswell. But what type of plug would be best for this type of high power setup. Any help to resolve my confusion of all the differant types of plugs available would be greatly appreciated. Thanx in advance.
That MSD system is most likely a waste of money. Stock Honda ignitions are good up to 600whp easy. Denso Iridiums. http://www.sparkplugs.com/glossaryImages/499.jpg
Thanx for the link. Why you say that about the MSD? I was under the impression that the stock parts loose their power at the upper RPM range. Got a great deal on the stuff anyways. Might aswell use em.
Well atleast you didn't pay a lot then. It's not going to help or hurt, untill your pushing big numbers. The fact is, the Honda ignition system is really good. It's not a [shitty] domestic ignition. Instead of me explaining what's already been explained, read through this instead. http://hondaswap.com/general-tech-maintenance/what-do-you-think-about-msd-ignition-83077/
Well if what they said about running forced induction is true then I will probably need it. But I will just play around with it and see what happens. Thanx for your info. Much appreciated.
