up and down in the idle
Discussion in 'HYBRID -> EG-EK / DC' started by 97hondacivicex, Feb 28, 2008.
  1. 97hondacivicex
    97hondacivicex New Member
    i know people say its the tps sensor but it was workign fin untill i put on a blox 72mm throttle body on a 97 honda civic ex.. what could cause that.. i put the old one on and it works just fine... then i put the blox on and it is messed up again.. what might be causing it.. there is no vacume leak i sprayed starting fluid and it didnt make a difference so i dont know what it might be can anyone help
  2. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Ive seen the fast idle valve on 1st gen crx's and 4th gen accords cause this. To fix it you have to take the brass plate with two screws off and use a big screw driver to turn the black valve inside clockwise slowly until it stops..
    Apparently vibrations cause it to back out over time and the wax valve in there doesnt stay where it should when the car warms up and bounces up and down. Its worth a try. I dont know if it can be done on your 97 though.
  3. Matts96HB
    Matts96HB . Moderator VIP
    IACV or TPS, check both of those.
    Could be either, is it the stock engine?
  4. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    could also be the idle screw needs to be adjusted after the car warms up....
  5. 97hondacivicex
    the throttle body has no idle screws on it.. it is a blox 72mm throttle body and we have tried everything... but what do you think of putting a y8 head on a y5 block.. that is our next move with the stock throttle body on there.. we have the vtec-e engine in there now but were thry the head thing and see how that work.. can any body give me input on that ...... is it worth it
  6. Lee7pcNOOb
    Lee7pcNOOb New Member
    Arlington
    You check all your vacumn lines? i had a vacumn line disconnected and it idled up and down.
