SleEPeR_CRX
Hello ladies... well theres some new idea's for my 13 second all motor LS project.
as many of u know im working on making my 1992 B18a CRX into a 13 second all motor car on a low ass budget. i just got my 13 lb clutch in, and my act pressure plate and disc. and now im starting to work on the head.I have crower 403's with titanium springs and retainers ready to go in after i take the head to the shop. a new plan has come up, to raise the compression by milling the head. i have to get new vavle seals and guides, and 3 angle valve grind with a mild PnP, and i thought a nice head milling would raise compression to around 10-10.5:1. any1 see any problem with this? can the head get milled this much? im keeping stock Pistons and rod's for price sake. im also possible getting a JDM 4-1 header with a 2.5" collector for 350 canadian, and a real mugen ECU, with 3 chips for 300 canadian. just depends on my $$ situation. right now ive spent the follow which are ALL IN CANADIAN DOLLERS
$400- 2.25" cat back exhaust with arospeed genII muffler( yes eww arospeed)
$80 - short ram intake with K&N filter
$5 - dryer tubing running from bumper to intake cone.
$80 - lightened integra flywheel ( 13lbs)
$650 - ACT clutch and pressure plate
$1300 - crower 403 cams with titanium springs and retainers
$150- Block Guard.
In shop, is my head
$400- new valve seals and guides, mild PnP, 3 angle valve grind, and MAYBE deck it to raise compression
coming soon
JDM 4-1 header
Mugen ECU with 3 different chips
Ill keep ya'll posted after i take her to the track
also, my question was. how far can i mill the head to get max compression ( would like 10-10.5:1)
Thanks
$150- Block Guard.
In shop, is my head
coming soon
JDM 4-1 header
Thanks
