upper control arm bushings
Discussion in 'Prelude' started by jtdesigns, Dec 10, 2006.
  1. jtdesigns
    jtdesigns New Member
    I have a design to make upper control arm bushings that throw our ludes camber off. this after about a month of looking for them on line so i drew a design on auto-cad and found the materials. just want some feed back from any that think these will work and might be interested in getting some for their own cars
    the first picture is the design
    the second is the nylon thats going to get machined down to specs
    next is nylon also its called nylon 101 stronger then polly but still gives.
    next is the hardware i chosen thats stronger then the oem bolts
    next is all the parts
    sometime next week i'll have the bushings done,,,,jt
  2. jtdesigns
    done
    got them cut and one pressed in now have to do the others. will send pictures of complete process ,,,,,jt
  3. stepheng2010
    stepheng2010 New Member
    Kansas
    hi i was wondering how those bushings have worked out for you?
  4. trev0006
    trev0006 Banned
    thanks for the pics
  5. efhondakid
    Akron-Canton, Ohio
    Please check dates before posting.
