urgent help 1990 civic
hoochhenry
hi there just need info i have done a 1.6 vtec conversion on my 1.3 civic just need some help on this matter as im doing all the work myself is there a fuel pump in the 1.3 carb engine could there be one in the tank or do i have to run a pump in the tank and lines up to the 1.6 vtec engine any help would be great thanks
well theres a pump somewhere but dont know if its in the tank or not
I imagine your fuel tank has provisions for a fuel pump for mpfi setup cars because half of the ef's sold had mpfi. You should be able to easily access the pump location by pulling the back seat and removing the cover to the top of the fuel pump. Then hopefully you can get an entire pump assembly from a junkyard mpfi car, drop it in, wire it up, and go.
