USDM VS JDM ECU's
Discussion in 'ECU's, Electronics, and Tuning' started by WannabeSI, Dec 25, 2002.
  1. WannabeSI
    WannabeSI Senior Member
    I have a B16a obdII swap and I have the jdm ecu that came with it and a usdm obdII ecu from a 99-00 si what one is better? do you know the differences between them? Let me know Thanks!
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You could try plugging them in and seeing if there is any difference.In my old 86 si I switched to a edm ecu and it made a difference,so try it.
  3. pissedoffsol
    run the 99 si ecu
    jdm ecus are speed limited to 113.
  4. ngq
    ngq Member
    jdm ecu looks for higher ron (octane) than usdm ecu & 99 si is obd2b (last
    plug on ecu empty).
