using chain wrench on pulley
Discussion in 'Engine Building' started by joker01, Aug 23, 2011.
  1. joker01
    joker01 Member
    caribbean, St.Lucia
    hey guys got fustrated with waiting for a mechanic to help me out i saw guy post a vid on youtube with him using a chain wrench to help remove crank pulley bolt and i am gin to get one tomor but the dude did show exactly weh he mouted up the chain wrench on the pulley n how he did so if anyone here has ever attempted this plz let me kno how thnx
  2. efhondakid
    Akron-Canton, Ohio
    Ive seen them work and Ive seen them not.
  3. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    id say just go get the pulley holder. it was so much easier
  4. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    pully holder x2. 50 bucks on ebay, it pays for itself the first time you get the bolt off in 2min..
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Pulley holders do not work if there's no cut-out for them. IMO, big impact wrench is the easiest.
  6. blong401
    blong401 New Member
    chain wrench will work. just make sure you cut a little peice off an old drive belt to place between the chain wrench and crank so you won't damage it. I'm a tech for toyota and that's how i remove the cranks pulley.
  7. |Chaz|
    |Chaz| Well-Known Member VIP
    Rent a big ass electric impact wrench, cheapest way to do it.
  8. E_SolSi
    this will get it off
    Ingersoll-Rand 3955B2TI Impact Wrench, 1.5 In Dr, 1600-4000 Ft Lb
    Air Inlet (In.) ------------------------------ 1/2
    Anvil --------------------------------------- Standard
    Average CFM @ 15 Second Run Time ----- 15.0
    CFM @ Full Load -------------------------- 80.0
    Free Speed (RPM) ------------------------- 2750
    Housing ------------------------------------ Titanium Hammer Case
    Item ---------------------------------------- Pneumatic Impact Wrench
    Max. Bolt Capacity (In.) -------------------- 1-1/2
    Max. Torque (Ft.-Lb.) ---------------------- 5000
    Min. Hose (In.) ----------------------------- 3/4
    Overall Length (In.) ------------------------- 16-1/2
    Required Pressure (PSI) -------------------- 90
    Retainer Type ------------------------------ Thru Hole
    SKUs -------------------------------------- 1FYD4
    Square Drive Size (In.) --------------------- 1-1/2
    Style --------------------------------------- D-Handle
    Torque Range (Ft.-Lb.) -------------------- 1600 to 4000
    Type --------------------------------------- Industrial Duty
    Weight ------------------------------------- 38.13
    Weight (Lbs.) ------------------------------ 34.6
  9. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Oh my, that's a whole lotta powa! It might flip the motor over from all the torque and cause some serious damage :p
  10. K2e2vin
    Raleigh, NC
    wow 1.5" drive; do they even make a 17mm socket for that? lol
  11. efhondakid
    Akron-Canton, Ohio
    The motor? More like the whole car!
  12. joker01
    joker01 Member
    caribbean, St.Lucia
    the pulley tool wotn work on my crank and impact wrench cant rent those tolls here n i dont trust anyone wit my car at the mechanics shop on my island i wonder if i jam the toque converter if it will work
  13. K2e2vin
    Raleigh, NC
    They have tools that hold the flywheel or you can try using a screwdriver or something(I've never had luck with that).
    You don't have to drop your car off at the auto shop for them to loosen it. Usually, they can get to it by simply turning the wheel or just removing that one wheel, zip it off with the gun, then reinstall the bolt with a ratchet so you can take it off yourself when you get home.
  14. Jeef
    Jeef NO MA'AM Moderator VIP
    I bet the user would be thrown around doing circles.
  15. joker01
    joker01 Member
    caribbean, St.Lucia
  16. joker01
    joker01 Member
    caribbean, St.Lucia
    hey guys updating this thread, got my nigga to remove the pulley bolt by jamming the toque converter wit an allan key and it worked so we replaced water pump and timed engined but it still wasnt starting....so we diagnosed the prob the to b the rotor screw got loose and fucked up inside the dizzy ama post pic tomorr
  17. joker01
    joker01 Member
    caribbean, St.Lucia
    hey guys i might have to chnge my ecu so which one would i have to use on it cuz am still wit my auto tranny wit a d15b non vtec motor
  18. K2e2vin
    Raleigh, NC
    Assuming it's OBD1, use a auto P06 out of a 92-95 Civic DX.
  19. joker01
    joker01 Member
    caribbean, St.Lucia
    jus identified the ecu its obd0 :[
