V-AFC2 setup?
Discussion in 'Civic - EP, FA, FG' started by onehavickman, Dec 19, 2007.
  1. onehavickman
    onehavickman New Member
    Hey, I'm a newbie to this Honda stuff. More of a biker and Chevy guy but was always curious about the hype. Sooo, I bought a 95 accord ex with a B18c swapped out from a Integra type R. It has a Apexi V-AFC2 controller installed and I was wondering if anyone out there is using it. I could use some help with some info on what setups you guys and gals are running on it. I have the manual so changing the parameters won't be a problem. I just need some base line info.
    1995 Honda Civic Ex Coupe
    JDM B18c Swap
    5spd
    Suspension:
    Coilovers
    Front and Back Camber Kit
    Neuspeed Front Upper Strut Bar
    Neuspeed Rear Lower STrut Bar
    Exterior:
    17" ADR M-Sport Rims (Example Picture Below)
    (Not the rims mounted on the Vehicle in pics)
    Rear Fog Light
    Wings West Mugen Style Side Skirts
    Engine:
    JDM B18c
    DC Header
    ACT Street Strip Clutch With Heavy Duty Pressure Plate
    MSD Ignition Wires
    Short Ram Intake
    Apexi World Sport II Exhaust
    Greddy Oil Catch Can
    Rage Racing Cam Gears
    New HeadGasket (Changed when did the swap to be safe)
    New Timing Belt (Changed when did the swap to be safe)
    New Water Pump (Changed when did the swap to be safe)
    New Timing Belt Tensioner (Changed when did the swap to be safe)
    New Fuel Filter (Changed when did the swap to be safe)
    Skunk2 Vtec Solenoid Cover
    Skunk2 Pro Series Intake Manifold
  2. onehavickman
    what kind of mods do you recommend that would make this unit worth it?:confused:
  3. onehavickman
    Thanks, B
    By the way I do have a DC header installed along with a 2 1/2" straight pipe to the exaust. Also on medium to hard acceleration I can hear a whistling sound coming from the motor.....any idea on what that is?
