v-tec/oil
95G S R
this might be a stupid question but i gota know, on the valve cover of my b18c1 you can pour oil down into the cams adn valves and all that good shit... how do you drain it and how much oil should be in there ?
hahah.. how do you drain oil?? on the bottom of the motor its called an oil pan.. there is a 14mm bolt (i believe) that you need to remove.. make sure there is an oil drain pan below before removing.. take the oil cap off first.. let all the oil drain.. replace bolt.. fill with 4.5 qrts of 5w30 by "pouring oil down into the cams adn valves and all that good shit"
lol thats not what i meant , i was thinking my differental fluid, i was thinking something different, my bad for wasting your time...lol
you know you didnt know... lmao... its koo though... but its actually 4 and 1/5 quarts of oil... and depending on your miles i would put maybe some thicker oil... or oil stabiliser
