V-tec Wiring
Discussion in 'HYBRID -> ED-EF / DA' started by 90integb16a, May 2, 2003.
  1. 90integb16a
    90integb16a Junior Member
    I'm swaping in a gen 1 jdm b16a V-tec into a 1990 Integra. I still need an ecu (I was told a PR3 ODB0 will work, is that the right one?) and I know about the extra wiring for v-tec but I dont what to use and where to route the wires(connections and all)PLEASE HELP!!!!
  2. pissedoffsol
    if you have left over wire thats long enough, use it.
    else get some 14 or 16 gauge i think it is and run it.
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    the obd0 pr3 is correct
  4. doofnoil
    doofnoil Senior Member
  5. Nerologic
    Nerologic Member
    the PW0 will work fine also if you can find it, its the PR3 just out of an integ
  6. legutki
    legutki Senior Member
    ask hasport they sell harnesses with plugs ,directions, and everything you need to know
  7. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    don't put a B16 into it... its worthless. I'd rather just have the B18a. The B16 is torqueless. If youo already have the B16, just go LS/VTEC and sell the B16 block.
  8. 90integb16a
    Thanks for all of your help, I found a kit at Hasport.
