Hey guys quick question anytime you would change cams from stock to some type of aftermarket cam (I'll be doing this on a B16 but i mean on any motor in general) Like i will be doing in a few months on my b16 do you need to degree the cams and check v2v and p2v clearances or are there just certain times you have to. For example only if you get the head machined or after installing new valvetrain Read more at v2v clearance v2p clearance and degreeing cams question - Honda-Tech
