ive tired using this one before,but the problem is,the civic doesnt have those 2 solenoids on the firewall..i have one and then that block thing,,so what i did was tried to run them as close as i could,,using the d16a6 diagram,,also the metal lines that bolt to the back of the manifld,do i absolutely need them,because i have waaay more lines than that,but i already took it off,and things look a little easier,dunno if itll work or not,,but anywayz thanx for cchiming inhere is one for 93 - don't know how much different 90 is, if any
what do you mean all the extra shit that isnt necessary??get a obd-1 manifold off a LS.. way way way easier and 10 times cleaner wont need all that extra shit thats not necessary.. i had one on my 91 integra while i was getting my head built... i have one if u want it... ill just send it to you.. its bare but way better than a obd-0 one then u just transfer everything over
i wasnt sure if i could go by that,,cuz its wasnt the same motor but if i can use that then thatd be awesomeYou hood doesn't have the vacuum diagram sticker anymore?
i have them all run,,im just waiting on a throttle cable,clutch cable bracket,and a dizzy now,,the car has been sitting for like 3 weeks without anything done to it,
