Vacume Lines
Travis
hello i just put a JDM b16 in my '93 teg and I was wanting to know if any one could take a pic of there tegs intake manifold so I can see the routing. The routing of the lines are different from my stock b18. My check engine light is on and I can't get it to go off....what could it be could it be? My IAC or my TPS or something? My idle is going up and down 700 rpms. Any help would be great.
Could all of it be cause of my TPS or IAC. ??????
Thanks, Travis
Thanks, Travis
sounds like you have a vacuum leak if your idle is surging. Check all your lines, and make sure EVERYTHING is hooked up
do you have your EGR hooked up right?
