lmao...
yea, i have been thinking of doing a turbo setup on my rex for some time now... have some parts here and there for it already... as we all do...
but then i was thinking about the vacuum advanced distributor...
not really sure how i could "tune" this either since the timing is sort of mechanical with a vacuum dependency thrown in there to mix it up...
the crx si turbo page i read suggested using an MSD device to control timing...
i know for ghetto rigs you need to check valve the MAP so it won;t read boost...
but, what to do about the timing...
i would think setting it at maybe 5 degrees after top dead center would be a reasonable (SAFE) place for it to spark all the way through the power range...
obviously no vacuum advance cause there's postivie manifold pressure, plus i don't want it advancing and grenading the motor...
