Vacuum Diagram help
Discussion in 'Forced Induction' started by Stark3728, Mar 9, 2007.
  1. Stark3728
    Stark3728 New Member
    I have a turbo for my 1998 Civic EX (D16Y8), but I don't have the vacuum diagrams to install it. Can anyone help me out?
  2. Ignorant import guy
    Ignorant import guy Senior Member
    there should be like 2 vacuum hoses on the intake manifold one has a very small diameter and one a bit larger...i have the same engine and i just used a brass t fitting on the smaller diamerter one (this one connects the fuel pressure regulator to the IM) to hook up my fmu (if you're using one)...for my BOV i used a brass t fitting and used the larger hose everything seems to work pretty well. also fmu probably isn't the best way to go i'm just using it temporarily
