VAFC SETTINGS
Discussion in 'ECU's, Electronics, and Tuning' started by crxlsvtec1221, Dec 10, 2004.
  1. crxlsvtec1221
    crxlsvtec1221 Member
    Philly,PA
    I got a vafc controller and I just want to install it with out causing any problems the wiring is not the problem it the setting after turning it on how do I set it without seriously damaging the car performance wise. If it helps I have a 92 civic hatch w/ a d16z6
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Just run it flat ( not adjusted) till you can get it on a dyno with wideband, and then have a tuner play with it.
  3. projekteg
    projekteg Senior Member
    set it for 4 cyl. car, arrow pointing uppter right corner, pressure sensor type 06 in and 06 out, and set all your fuel settings at 0%
  4. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    isn't there a way on the vafc to set it not to even run just to use it as a vtec controller and a sensor checker?
  5. brc80
    brc80 Senior Member
    Southern California
    Yes just hook it up and leave it at zero, like 92b16vx said. just use the cross over setting for what you want.
