Vafc Throwing Map Sensor Code...please Help!
wtc7676
Member
Alright, when I hook up the VAFC, my ECU throws a code 3 (map sensor)...when I unplug the wires from the vafc that control pressure sensor, the ecu no longer throws a code....
HELP!!!!!!!!!!!!!!!!
Will
does it throw a code right away or after u drive?
did u down load the revised version of the vafc wireing from apexi and wire it that way!!!
are you using the honda map.. i'm gonna guess that it is because you are using a vafc with a jrsc.. get a real fuel management sysetm yO
did you get jacskson's map sensor controller thinggee? they have a special thing jsut for this problem.
http://jacksonracing.com/pages/partsacura.html
