valve adjustment,
chipDA9
i need to adjust valves on a 93 integra ls, i hav the clearnces but how do i turn the crnk to get to TDC?
Go get a repair manual for you car it sounds like you'll need one to do the job correctly. To turn the crank all you have to do is put a socket on the crank pulley, and to get to TDC you just line up the 0 degree mark on the crank pulley with the 0 degree mark on the timing cover and make sure the cams are pointing up.. :shrug2:
