Helloween2006
I just installed a Cold Air Intake onto a 93 Honda Del Sol Si (D16Z6, 1.6L SOHC Vtec), i have a hose going from the back of the valve cover into the intake tube. I was wondering if i remove the hose and install a little filter onto the valve cover, will it cause a problem with pressure, sensoring or anything else?. I want to do this so i can remove the hot air going into the intake tube from the engine.
