Originally posted by asmallsol@Jan 8 2004, 10:25 PM
for plugs, use NGK plugs.
PCV valve should be like $5-10 and if it is like my old d-series, it should be extremly easy to change.
For the temp switch, just swap it out with the one from your old engine. I would do the same with your starter.
I have 4 shiny new NGK's sitting right here, a new gapper, spark plug socket....
The pcv valve was 6.50 at Canadian Tire (26 @ honda)
"Where" is the temp sensor on a D15B2...and that will fit a B1...are they the same??
Yah...I had planned on looking into the starter from my old engine and see if that did the trick
Jason
