valve cover question
Discussion in 'Civic and CRX - EF' started by chadcharb, Nov 4, 2009.
  1. chadcharb
    maple valley, Wa
    will a v-tec valve cover work on a non v-tec head? And would a d16 valve cover work on a d15?
  2. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    1, it's vtec not vtech, it's not the electronic company. and 2 why would you want to swap over the valve cover? did you do a mini me swap?
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    no a vtec valve cover wont fit on a nonvtec head..vtec spark plugs are in the front upper part of the head.where non vtec are in the rear upper..
    as for 1.6 and 1.5 if its non vtec then im pretty sure they will fit
  4. Bobby17772
    Enfield, CT
  5. chadcharb
    maple valley, Wa
    I'm not sure if you read what I put in my post but it doesn't say vtech, it says vtec! And I was just curious, I want a "wrinkle" red valve cover for my y7 but vtec valve covers are easier to find than non in this style. Thanks for the info guys
  6. BrutalB83
    Rochester Hills, MI
    Step 1 - Buy this: Klean Strip Aircraft Remover Paint Stripper Spray Can:eBay Motors (item 200311516591 end time Nov-14-09 15:50:59 PST)
    Step 2 - Use it on your valve cover
    Step 3 - Buy this: Amazon.com: VHT SP204 Wrinkle Plus Coating Red Can - 11 oz.: Automotive
    Step 4 - Use it on your valve cover
    Step 5 - Enjoy your wrinkle red Y7 valve cover
  7. chadcharb
    maple valley, Wa
  8. DESPAIN
    flower mound TX
  9. josh_crewdson@y
    josh_crewdson@y New Member
    nova
  10. chadcharb
    maple valley, Wa
    d16y7
  11. jlicrx
    jlicrx Senior Member
    Colorado Springs
    D16Y7 non-VTEC spark plugs are in the front just like a D16Y8 VTEC
  12. chadcharb
    maple valley, Wa
    so are you saying a y8 cover will fit a y7 head in this case?
  13. jlicrx
    Colorado Springs
    yes, they are the same - the Y8 doesn't say VTEC, if you were looking for that
  14. chadcharb
    maple valley, Wa
  15. jlicrx
    Colorado Springs
    the Y7 and Y8 covers do say HONDA on them
  16. chadcharb
    maple valley, Wa
    yea that was just what I found in a quick search.
  17. 94civicturbo
    94civicturbo New Member
    Liberty, IN
    i didnt prime mine on my prelude and it turned out fine so i dont think you would need to just prep it real good
  18. 91civisedaner
    91civisedaner Senior Citizen
    oregon city or
    I didn't prime coat mine just prepped it good.
  19. chadcharb
    maple valley, Wa
    that looks great did you tape off the letters or just scrape them?
  20. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    as long as its from a 96-00 d series non vtec the cover will work
