valve covers
kimchimik
Member
well i'm planning on donig a LS/Vtec conversion on my 98 integra and i'm trying to go for a sleeper effect on my car as much as i can, what i want to do is put my B18B valve cover that doesn't say "DOHC VTEC" on in place of the one iwill be getting with my B16 headswap, i was wondering if they are interchangeable, i know most things on the B series motors are but a friend was telling me they weren't.
asmallsol
Super Moderator
just get a black dohc one instead of a red type R or a fake MUGEN one off ebay. People still want to admire your car alittle bit and remember power does not = rice
chet
ls valve covers are not compatible. if you compare the two you'll see that there isn't enough room for the rocker arms during vtec.
kimchimik
Member
yeah that was the alternative but it doesn't have the same look of the dohc non-vtec valve cover, which is the stock look but oh well i'll just have to live with the vtec valve cover :rolleyes:
asmallsol
Super Moderator
one thing is dont put the spark plug wire cover one (the little silver thing in the middle) that makes it look like a ls cover then grind the dohc vtec off then get black paint to cover it
it would have to get powder coated to look right or else you will have a nice obvious flat spot where it was grinded. everyone will be like "what did you grind the VTEC off for?"
tb820
One way or another, someone who knows will know what they are looking at if you do grind off the vtec and leave the wire cover off. If you want a sleeper, go for the STOCK look with the hub caps and stock suspension..... yeah....
kimchimik
Member
well my year integra comes with alloy rims, which i am sticking with and around here in southern california i always get a bunch of people asking me why my integra is so high off the ground, i guess everybody here lowers their intergras that it's become so common place around here i was going to do a 2" drop on it anyways just so i can get less body roll and get rid of the wheel well gap
knowledge
deffinately lower it. there are alot of advantages of dropping it! the only advantage you have by keeping it stock is the sleeper look. i would drop it!
kimchimik
Member
i'm definately doing it, i'm just kinda bummed that i my b18b valve cover won't fit the dohc vtec heads but oh well i don't wanna make it look like i'm trying too hard for the sleeper look
