No, unless if was applied with a sealant and it breaks when coming off. But it is a good idea to replace the spark plug access gaskets as oil will build up in your spark plug wells. Just make sure it is in good shape if you are going to reuse it.
are you trying to take the head off or the valve cover? if you're pulling the head off, you should replace the gasket but if it's only the valve cover re-read 92b16's post.
when i pull the valve cover off i just apply some copper sealant and put the valve cover back on. you have to let the sealant sit for a little bit before you re-install the valve cover.
i was gonna take the cover off to polish and paint it. then i was gonna put it back on, and just in case i didnt like the way it looked i would just take it back off and re-use the gasket. put common sense just hit me, and usually when the cover comes off so does bits and peices of the gasket. so ill just make sure that i do a good job the first time, buy the gasket, and stop trying to be a cheap-ass.
well after it comes back from getting painted I would inspect the gasket, and if it's a little tough crunchy like, brittle then I would just replace it...
If your painting the valve cover, replace the gasket. I wouldnt take the chance of getting hot oil all over fresh paint. Then youll just have to do it over agian.
20 horse, Holy.... Mang, someone help me send meall the left over paint so I can get 20 horses. I'm kidding, im thinking we have a ricer on our hands... it if isnt performance oriented then it's RICE. haha
why don't you just buy a TypeR valve cover or a spoon/mugen/jun/etc.
the typeR will only add about as much HP as painting yours, but for the $800 or so price tag that one of the others will set you back you will get like 50hp to the wheels no problem.... and you will get laid!
