Valve Lash Spec
Discussion in 'Engine Building' started by RickParker, Apr 17, 2010.
  1. RickParker
    RickParker New Member
    Shippensburg, PA
    Just want to double check the factory Valve Lash for the B18.
    Intake: 0.003"-0.005"
    Exhaust: 0.006"-0.008"
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    I just did mine today and I do 0.006 for intake and 0.007 for exhaust on my B16A But you did not state if it was a B18C or a B18A/B
    If its a B18C....you specs for intake side are too tight. Not sure on the Non-VTEC B series heads. I think they are like mine but I could be wrong. I read a googled page that had the specs you refer to but it was for a B18A....not sure though. I know my B16A is the same specs as a B18C for sure.
  3. RickParker
    Shippensburg, PA
    its the B18B.. i googled mine too and found three diff specs.. The helms manuall had the one listed above,, chilton had the ones listed that you mentioned and clubintegra had a link for specs for 0.005IN, 0.009 EX. Ive never seen a spread like the last one so im elliminating that
  4. CAFROG
    NOR-CAL
    B18B is like mine....I think. Let me look at my Helm (it has the B18B too)
  5. CAFROG
    NOR-CAL
    My Helm says your spec's too. So you were right! At least I always trust my helm manual. and its was isentical to your numbers. It was a spec sheet with the listing for a B18B1 (USDM)
    1 person likes this.
  6. RickParker
    Shippensburg, PA
    Thanks.. got the head put on and will set the valve lash tomorrow.. another question though.. how do i post pics??
  7. CAFROG
    NOR-CAL
    Need to upload them to a photo share web site then get their URL (I think...its one of the possible links to copy) and paste it here. Try the URL one and preview it.
  8. RickParker
    Shippensburg, PA
    what is a good photo share website?
  9. CAFROG
    NOR-CAL
  10. RickParker
    Shippensburg, PA
    Thanks.. will post pics of the worn out teg.. lol
  11. bigpapadee117
    bigpapadee117 New Member
    b18c1 valve ajustment
    hey i have a b18c1 wats the specs on that, the car runs fine but the valves are knocking really bad..
  12. CAFROG
    NOR-CAL
    Intake is 0.15mm-0.17mm
    Exhaust is 0.17mm-0.21mm (not sure on the high end of this one but stay around 0.18mm and you will be okay)
  13. bigpapadee117
