valve problems ... i think
Discussion in 'Civic and del Sol - EG and EK' started by Blakwolf9666, Jan 12, 2011.
  1. Blakwolf9666
    Blakwolf9666 Member
    Miami
    ok its a 92 civic lx sedan, i just did replaced the water pump and started the car and it started running weird, almost like a misfire but not. had someone check it out, timing, compression, and he said it could just be a fouled up injector and to get some injector cleaner. if that didnt help he said it may also be that the valves need to be adjusted. if i need to adjust the valves though i was wondering what would be the optimum clearance? i know the manual says to make sure its between this ## and that ## but where which would be the best to set it to?
  2. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    if your valves need adjusted your car will sound like a sewing machine. <<< really fast tap. not so much on loudness.
    and to adjust them do the number that it recommends. if you do it to loose it will still tap to tight and you could mess it up.
  3. Blakwolf9666
    Blakwolf9666 Member
    Miami
    its been awhile since ive heard what a sewing maching sounds like but i believe i did hear some tapping when we were listening to it ... ill probly get a new fuel filter as well just in case and i dont know if it been changed or not, after all nothing else has been (axles, bearings, and what not)
  4. lostsoulzprophet
    georgia
    adjusting valves is quick and free if you have the tools. just make sure you take your time and get them right. and make sure you rotate your engine properly which is counter clock wise.
  5. Blakwolf9666
    Blakwolf9666 Member
    Miami
    so when i do get that fixed should it also take care of the whitish smoke from the exhaust? because ive noticed it does that till it gets warmed up
  6. lostsoulzprophet
    georgia
    probably not. how many miles is on your engine. that could be valve guide seals. or piston rings.
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    The clearance should be listed somewhere under the hood or on the airbox.
    Did you guys make sure the cam timing is correct?
  8. hondafreak513
    hondafreak513 New Member
    O hi O
    The white smoke could just be condensation...
  9. lostsoulzprophet
    georgia
    yea true. how bad is it tho. is it just little or is it medium to alot.
  10. Blakwolf9666
    Blakwolf9666 Member
    Miami
    that may be it since it is an aftermarket exhaust (yonaka) and its not to bad, just checking though you know hoping its not something else, this car after all has needed more than i thought.
  11. lostsoulzprophet
    georgia
    if its not bad then shouldnt worry about it. just make sure your check oil every once and a while. just in case it burns it a little.
