okay. I have a swapped crx with an LS (93) now I'm doing a valve job at home. I need the clearance specs. if you can help cool.... but please dont tell me to take it somewhere....
Intake: 0.006-0.007 (.15-.19mm) Exhaust: 0.007-0.008 (.17-.21mm) Lock nut torque: 18ft lbs. Adjust the valves with the engine cold. Adjust in this order: Cylinder 1 (rotate crankshaft 180 degrees counter clockwise), Cylinder 3 (rotate 180), Cylinder 4 (rotate 180), Cylinder 2.
thanks alot man. did you have the book on the vehicle or did you look it up somewhere. cause if you looked it up then I'd love to know the site for future reference.
Taken from a Chilton. I have haynes and chilton manuals on every 90's civic, crx, sol, and teggy. But if you google "valve lash integra" it'll pull up several sites with good info.
