hondapowerb16a2
had a few questions about building a b16a. im doing ctr pistons and ctr or skunk2 stg 1 cams. if i go with the ctr cams i heard you can switch the b16a intake valve springs to the exhaust and and do itr intake springs on the intake. does this work well or is it kinda ghetto? also can i use my b16 retainers on the itr springs or do i need to get the itr retainers? and also with that setup i have an itr ecu in my garage would it run that setup well or do i need to get some engine management? would a vafc be adequate? thanks
