Variable boost
Discussion in 'Forced Induction' started by christ.deyoung, Jul 4, 2007.
  1. christ.deyoung
    christ.deyoung CRF450R
    Nova Scotia, Canada
    Does such an item exist which allows you to change your boost level/fuel mappings on the fly? For example, a motor which has multiple boost settings; maybe a minimum of 0-1 psi, and a max of 12, (or whatever).
    Feel free to burn me out for asking stupid questions.
  2. reikoshea
    Dallas, TX
    ive never heard of such a thing being available on the retail market, but im sure its coming.
    you can setup an electronic boost controller and have maps ready on your laptop for whatever you wanna run, but i think thats the closest thing thats available for retail.
  3. christ.deyoung
    Nova Scotia, Canada
    So what are some of the better boost controllers you're referring to? And roughly how long would it take to change your settings....like 10- 15 seconds?
    Will a turbocharged engine with the boost down to 0 psi behave roughly the same as a NA engine? I'm basically looking for an engine that can run with little to no boost and be easy on gas, and have the option to jack up the boost when you want all your power. Suggestions? Looking for 275-300 Hp out of a B16B.
  4. pissedoffsol
    a boost controller can only go up, not down.
    your minimum is set by your wastegate spring.
    your maximum is about double that in psi with a boost controller.
    If you want to get good gas mileage, get a larger turbo that doesn't spool up so quick, so normal crusiing under 3500 rpms you aren't in boost.
    you can have a 500hp car and still get 25mpg. its all about how much of your right foot you use.
  5. reikoshea
    Dallas, TX
    :werd:
    rewriting an ostrich rom emulator is about a 2 or 3 minute ordeal. If you wanna switch between 7 and 15lbs of boost, factor in a 3 minute time frame for the switch.
  6. christ.deyoung
    Nova Scotia, Canada
    well...i'm looking for around 300+hp out of a B16B, and the goal is to get 30+ mpg (light footing of course). So now, would this thing be gutless at 3500 with a large turbo?
    Any more suggestions perhaps?
  7. reikoshea
    Dallas, TX
    unless youve already bought the b16b, buy a b18b and boost that...300 is asking a lot from a b16b with that CR.
  8. christ.deyoung
    Nova Scotia, Canada
    I havent bought anything yet...however I kind of want to turbo the higher CR engine, so that it's more fuel efficient when running with little boost. Also the same reason why I wanted to go with the 1.6, plus the 9000 RPM rev limiter is appealing.
    What exactly makes it difficult to get that power out of the high CR engine? Just the required fuel/engine management system?
    And would it be reccomended or required to change the connecting rods and pistons?
  9. reikoshea
    Dallas, TX
    im going to stop here and tell you to search.
    high CR + boost = bang.
    The higher the CR the lower threshold for error you have in tuning a FI car.
  10. christ.deyoung
    Nova Scotia, Canada
    Fair enough...what's a good safe CR to work with?
    Any suggestions on what I should run for a setup?
  11. reikoshea
    Dallas, TX
    i wouldnt go any higher than 10:1 (personally)...thats why i suggested you get a b18b rather than a b16b
  12. christ.deyoung
    Nova Scotia, Canada
    Ok, so say I go with the B18C1 --> CR of 10.0:1 ; If I go with this engine boosted, Is it reasonable to expect 250,000+ Km's out of the motor, and/or is it advisable to upgrade the bottom end and valvetrain. Keeping in mind that this will be a DD car, that will be lit up regularily (maybe few times a week, and never for long periods of time).
  13. reikoshea
    Dallas, TX
    its possible, but i wouldnt gaurentee it. A lot of the life of a FI engine is dictated by the way its driven and the tune of the engine.
  14. christ.deyoung
    Nova Scotia, Canada
    What are my options for engine management?
  15. ALEXBECK23
    ALEXBECK23 N/A boost=Turbo boost
    MD
    10-15 second..thats "fast and the furious" shit...just wait till next summer and you are gonna be able to see it in the next movie..:D get a electronic boost controller!!!!!!;)
  16. silver
    silver Senior Member
    St. Louis
    I think you're expecting the world from something unreasonable. If you want something that gets 30 mpg and >300 whp, buy a vette and put a bottle on it if you want more power.
    Wanting 300 whp out of a 1.6 liter engine, 30 mpg, multiple tunes, and have it not be gutless throughout most of the powerband is just asking for trouble. Pick and choose what you want.
  17. christ.deyoung
    Nova Scotia, Canada
    Well for one, expecting 300hp and 30 mpg from a 1.6 is absolutely NOT unreasonable. However I do realize it would have to be gutless down low. It sounds to me you just want to put your 2 cents in and cause an arguement. I'm here asking questions and looking for advice, so give me a break and shut up when you have nothing useful to say.
  18. silver
    St. Louis
    If you get your panties in a fucking bunch then get off of a forum. You asked a question and I gave you my opinion. If you've ever modded a car beyond I/H/E or basic crap then you should know you don't get everything and that's exactly what I said.
  19. reikoshea
    Dallas, TX
    christ...hes right...ive never heard of a b16turbo that gets 30+ MPG
  20. silver
    St. Louis
    That wasn't the main point I was making--it was about the powerband issue.
