vehicle immobilizer
Discussion in 'HYBRID -> EG-EK / DC' started by eric p, Jan 30, 2009.
  1. eric p
    eric p New Member
    i am putting a '99 ls motor into my 2000 dx civic. if i get the key and ignition switch from the integra will that solve the immobizer problem? can the acura dealer reflash the ecu to disable the immoblizer? thanks
  2. 92egSi
    92egSi I need DOHC VTEC
    I suggest giving honda a call to see what you need to have done.
  3. efhondakid
    Akron-Canton, Ohio
  4. eg6sir
    just chip the ecu and have the immobilizer removed .. keep it simple..
  5. efhondakid
    Akron-Canton, Ohio
    Didnt know you could do that, thats why I suggested going OBDI. :thumbsup:
  6. civich22aturbo
    civich22aturbo New Member
    Gibraltar
    As long as you have the key, ignition, immobilizer sender unit and the ecu from the same car it shouldn't be a problem.
