ok this is what i have done i put a 99-00 ex gauge cluster in my 91 hatch. ok now i got a 99 teggy vss top and a 97 del sol gear housing that goes in to the tranny. now hear is my issue i wired the vss like so power signal and ground now here are the wire colors i have yellow with black stripe as power yellow with white stripe for signal and black for ground. i wired it up that way and it is not working. but i am wondering if i wired the signal wrong but electrical is constant. this is how i wired the signal cluster to ecu to vss. or does it have to be different?? Estorvito read that the wire colors are this IGNITION=black/yellow GROUND=black VSS OUT=blue/white but i ran the switched poer to b4 on the ecu. i might just run it off the radio ign. i just need to get my speedo working lol
