vtec a little stronger???
Discussion in 'Civic and CRX - EF' started by theyangsta, Jul 29, 2009.
  1. LOWLIFE
    LOWLIFE Local Diesel Fanatic
    Fort Worthless
    how did you hide the N20?
    where did you put the nozzle at?
  2. D16SiHatch
    D16SiHatch New Member
    this thread is full of fail
  3. efhondakid
    Akron-Canton, Ohio
    Id rep you I could, I thought that was funny as hell for some reason.
  4. 97hatch
    97hatch ?
    Anderson IN
    air filter directly on tb with bracket for nozle inside and lines covered in loom every thing else was mounted in the car
    including the fuel tap i cut and flared a T in to supply fuel
  5. LOWLIFE
    Fort Worthless
    i had planned on loomin it all up but the nozzle was my biggest issue i had, if someone knows what they are looking at it would be realitivly easy to spot even more so if a wire tuck has been done.
  6. blasterman87
    blasterman87 New Member
    run the hose in side your air intake, and put the nozzle inside the intake also.. so the only thing you need to hide is the hose going into the intake, and to make it look normal use the hole in the intake for venting the valve cover to feed the no2 line through, feeding the no2 line through a rubber hose will hide it very well..only hard part is making a bracket inside the intake (bc most cai's are aluminum)
  7. C1own3r
    C1own3r New Member
    So I have a 1998 sedan dx. It came with d16y7 nonvtec. I had a knock so I swap it to the jdm d15b. I had a guy do my swap and my vtec has never kicked. I don't want any one touching my car much more if I can help it. Can some one help me out with info. I'm running p28 and got everything from HMO BUT I have the harness from my d16y7. Please help with real info that may help.
  8. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    welcome to hondaswap, A start your own thread B do own research before posting this has been covered across the internet since the cars were new, you run 2 wires to the ecu http://hondaswap.com/threads/how-to-wire-vtec.40811/
