Vtec Code Gone
tab
Super Moderator
If I wired the VTEC correctly, my VTEC should work. The engine code for the VTEC is no longer being thrown by the computer. Would the code be thrown if any part was not right? What I mean is, if the code is gone, does this mean I am 100 % done with the VTEC wiring? Any and all comments appreciated here. Also, the one code that I have left is for the ECT, engine coolant temperature sensor. Which one is it? There are two switches, a sensor, and a sender, and I'm not sure why it is not working properly. Thanks.
That code being thrown would definitely cause VTEC to not engage. Engine temp is one of the things the ECU looks for when determining when VTEC engages.
