VTEC code with p75 ecu
Discussion in 'HYBRID -> EG-EK / DC' started by Uppertorso, Jun 29, 2005.
  1. Uppertorso
    Uppertorso Senior Member
    Winnipeg, Manitoba
    I have a 95 civic 4 door, with a B18 installed in it. There is a P75 ecu throwing code 22 and 21. These are VTEC codes!!??!!?? This is a non-vtec ecu. Has anyone encountered this before??? We have checked the wiring, all is ok. The vehicle also has a hesitation problem between 1000-2000 rpm.
    any input is appreciated
    Thanks
    AP
  2. pissedoffsol
    impossible. lol
    check that you're reading the codes correctly. sometimes its easy to confuse the long bleeps with the short bleeps
  3. Uppertorso
    Winnipeg, Manitoba
    I shit you not, these are the acutal codes, anyone have similar experience or input??
    AP
  4. DelSlo
    DelSlo Senior Member
    i had a p28 that i was told time and time and time again that it was a 5 spd, but it kept throwin an automatic tranny code haha, but im pretty fuckin sure it actually was an a/t ecu, the car would barely run! lol
    thats weird man, but yeah, ive mixed up codes before too. <_<
  5. 92civicb18b1
    92civicb18b1 The Trisexual
    you're reading the codes wrong or you don't have a p75.
    I was thinking the same thing, and I was reading the codes completely wrong.
  6. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    :withstupid:
  7. Uppertorso
    Winnipeg, Manitoba
    I hate to break the news to you, i work at a Honda dealership, I think we know how to read the codes. But we ensured that the ecu was a P75, we even took it apart to see if it was tampered with, and it is a virgin ecu (not modified for uberdata). Maybe we are missing something.....
    Anyways thanks for the imput.
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    If the ECU is brand new, as in you just opened the package from Honda, it could be a mix up at the factory. If not than it just isn't possible for an LS ECU to throw a vtec code, especially if it has been in use and hasn't done it before (re:factory defect).
  9. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    Maybe someone swapped the housings or swapped the labels.. Does it have the PINS for vtec?
  10. 92civicb18b1
    i can't help ya then.
    92b16vx said as much as can say about it now.
  11. pissedoffsol
    if you work at a dealer, why are you jumping ecus? throw the scan tool on it.
  12. kyleirwin
    kyleirwin Retired OG
    Vegas
    what board is it? it's printed on the board. also, take a pic of the inside of the ecu and post it if you can, i could tell you if it has the hardware for vtec. if it dosen't... you're just on crack... or something? :p .
  13. Uppertorso
    Winnipeg, Manitoba
    The computer we are using is from a running integra 1993.
    I will try to get some pictures of the ecu for you guys, but not till monday, we are closed for the weekend.
    I have heard from another source that maybe we should be using a p74, instead of a p75.
    Thanks guys
