vtec controller
Discussion in 'Civic and del Sol - EG and EK' started by joecivic, Feb 4, 2010.
  1. joecivic
    joecivic save the single cams
    baltimore
    hey i got a vtec controller i want to hook up to my civic and i got the wireing all straight from apexi the only thing im not sure about is what the settings should be when i first start it up i got a mini me swap in there with p28 ecu
  2. BrutalB83
    Rochester Hills, MI
    It's 2010 and people still use VTEC controllers?
  3. pooksy64
    pooksy64 RidetilldeathdousparT
    HOUSTON tX
  4. xeroxero
    xeroxero New Member
    Fayetteville Ga
    vtec controllers are fine, vtec should engage at 4500 rpms. you can play with it but thats where the fuel curve adjust for the bigger cam profile.
    Chipping the ecu is more costly and so is tuning. i do agree with a well chipped ecu THAT COMES FROM A REPUTABLE SHOP AND IS WARRANTIED... no ebay or craigslist garbage. HONDATA IS GOLD AND WORTH EVERY PENNY
  5. joecivic
    baltimore
    well i dont have very much dough to work with i got the controller off a freind awile back just wanna put it in cause my car runs sooooo rich just something i had lying around and wanted to use
  6. BrutalB83
    Rochester Hills, MI
    What do you think a VTEC controller is going to do for your "running rich" problem? You're going to want something more like a V-AFC, where you can tinker with the A/F ratios...
  7. EP3Hatch1987
    EP3Hatch1987 Meeeeooowww!!!!!
  8. joecivic
    baltimore
    i have a apexi VAFC 2 vtec controller
  9. joecivic
    baltimore
    so you can "tinker"with the A/F ratio with that
  10. ImportBanger
    ImportBanger New Member
    im kinda havin the same problem, i have a 98 civic and i put a 98+ gsr type r and it hook up direct but ive been reading about the v-tec and i dont no where to hook it up at. Wireing is where im a dumbass at, and other stuff but not sayin
  11. joecivic
    baltimore
    wiring a vtec is easy theres a write up on this site on how to do it in the refrence section.Im wireing a vtec controller
  12. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    well when you buy a vtec controller it comes with directions on how to wire them up.
    so the dude you got it from should have the directions.
    be careful when adjusting many people think they did minor adjustment only to find out they adjusted it to point of engine destroying
  13. caboose
    caboose USDM to the bone
    Hamilton, MI
    OOOO... the covented GSR Type R
  14. BrutalB83
    Rochester Hills, MI
    Well forgive me for criticizing, but you didn't say that it was a V-AFC. You just said it was a "VTEC controller". I wouldn't call a V-AFC a "VTEC controller", I would just call it a V-AFC.
    Anyway, as the other guy said, it should have come with directions, so if you didn't get them from the seller, check back and see if they still have them. If not, hit up the Apex'i website and see if they have directions available or a customer support line...
  15. joecivic
    baltimore
    i thank you guys for all your help
  16. joecivic
    baltimore
    i have air fuel gauge to help a little with tuning think i just need to lean it out a little my plugs get black and smell strong like gas
  17. joecivic
    baltimore
    went back to apexi online and got inital set up settings had the wiring before but not start up settings plan on putting it in later this week if the snow ever stops !!!!! we got like 10 inches on top of 2 feet that fell saturday WTF ill let ou know how that works out
