Vtec dont want work
Discussion in 'General Tech and Maintenance' started by shifter, Apr 5, 2006.
  1. shifter
    shifter Junior Member
    we have swaped in '94 civic coupe b16a engine. Stock engine was d15b7. stock p06 ecu i've swaped to p28 ecu. wrote p30 bin with switched of: knock sensor, VTP, injector test, eld and etc. wired wire from A4 ecu pin to a vtec solenoid. if i power it directly from battery + - vtec work, but ecu dont want to engage vtec (i've wired a bulb inline to vtec solenoid to look if ecu trying engage vtec.) ecu chiped with a Crome. vtec set at 4k..... no CELs. i've used another 100% working P28 - same result. why it dont want work?
  2. TurboMirage
    you need oil pressure to activate VTEC as well. Make sure your oil pressure sensor isn't off, or unplugged.
  3. shifter
    nono. everything is hooked up. i am getting no cels. if i connect + from battery directly o vtec valve - it's works. i hooked 12v lamp inline on wire wich goes from ecu to vtec valve. it not light ether...
