vanilladutch89
H22_(ivi)
i have a 92 civic with an h22 engine in it and as some may kno from other postes myvtec does not work and ive tried everything ive rewired to ecu from solenoid tested the solenoid with 12 v power it is good ive tried everything i herd would help or work soo heres my question if i booght a vtec controller could i bypass using the ecu like how do i install a vtec controller dosnt it bypass the ecu any way soo if i hooked one up would it enable me to use vtec if my ecu is the issue ??? and another thing does ne one have a diagram or anything on installing a vtec controller to a car and for use i have a p13 ecu if thats eneded and it is obd1 and its a h22 engine thanks any help is really apreciated
