VTEC Leaking
Discussion in 'General Tech and Maintenance' started by broken94accord, Jan 15, 2009.
  1. broken94accord
    broken94accord New Member
    colorado springs
    my vtec solenoid on my 1996 accord vtec is leaking oil underneath really bad any ideas? im throwing a CEL 21
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    replace the gasket
  3. broken94accord
    colorado springs
    where do i find the gasket for this?
  4. AHHVTEC
    Alabama
    honda dealer. or online somewhere
  5. broken94accord
    colorado springs
    could that fix my VTEC problem? as of right now i have no VTEC and im reving out at 5000RPM
  6. AHHVTEC
    Alabama
    it could yes. vtec has to have pressure to work. besides it needs to be fixed anyhow. give it a try
  7. broken94accord
    colorado springs
    ok thanks ill definately try it i just ordered a new vtec solenoid so ill put that in with gaskets. can i use gasket maker for that to see if it works?
  8. AHHVTEC
    Alabama
    no clue ive never tried that
  9. broken94accord
    colorado springs
    alright thanks well hopefully i can get my vtec working i did a motor swap and im throwing like 4 codes its just hell right now for me and this car
  10. haao13
    haao13 New Member
    PA
    i used that blue gasket maker, cant remember the name, when my solenoid was leaking at it only held for about two weeks.
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i wouldnt use a gasket maker,it will just clog up the ports,
    clean the surfaces really well and put a new gaset,but if your set on gasket maker use BLACK RTV and apply it smooth and even
  12. 95b16coupe
    95b16coupe New Member
    ct
    just use a new gasket. if you have 4 codes, the vtec problem could be any one of them.
  13. newb
    newb phresh VIP
    Backwoods Northwest
    Werd. I wouldnt even waste the time tryin to use gasket maker. Think of the saying, "If you dont have time to do it right, when will you have time to do it again?" It always applies.
  14. broken94accord
    colorado springs
    ok i ordered the new vtec solenoid from honda so ill replace that whole assembly will that help my problem with reving out at 5000RPM?
  15. newb
    newb phresh VIP
    Backwoods Northwest
    It could, but the problem might lay with one of the other codes your throwin.
  16. broken94accord
    colorado springs
    im throwing an ELD code, a misfire code, VTEC solenoid, and automatic transaxle but i have 5speed and i have no idea about the misfire how can i check misfires? ive got perfect compression all around
