vtec light
Discussion in 'ECU's, Electronics, and Tuning' started by hatchproject, Dec 21, 2002.
  1. hatchproject
    hatchproject Member
    what colour is the wire for the vtec solenoid on a p28 obd1?
  2. Havok
    Havok Senior Member
    Florida
  3. Cronic
    Cronic Junior Member
    I have installed one in my car as a warning for any failures of the VTEC, Lets you know certain things if pressure is not correct, or if the solenoid is bad, or if your low on oil.
    The light will actually throw a "code" if it's not working properly. It's interesting, the code is not exactly readable nor does it change, it just blinks once per second to let you know something is wrong, and it's dim.
    I used a HILED (blue) to light up once VTEC kicks in. It's a very simple mod, can be done for probably <$10 and 30 minuites. The last time VTEC didn't work a bolt was bouncing around in my valve train.... wasn't perty.
  4. hybridtech
    hybridtech Junior Member
    Texas
    When I let my friends drive they keep seeing the red light come on and they shift. Keeps them from ragging on it. :D
  5. RFHOMI2U
    RFHOMI2U Senior Member
    lol they think the vtec light is a shift light?? that's hillarious. I would love to play that trick on my friends. I'm interested in this now too. How did you wire up the light??? what wire did you hook it up to on the solenoid? can't you just hook it up to the yellow/green wire and then ground it??? would that work or no?
  6. crazydude75927
    crazydude75927 Junior Member
    vtec spool selonoid is A4 and vtec oil pressure is D6 hopethis helps
  7. crazydude75927
    I did the whole vtec light thing today for a dollar nigntyseven all i did was go to radio shack and buy a red light all the other things i needed were in my house
    1. red light 12 volt
    2. several feet of wire
    3. i used a male and female conector to splice into the vtec wire right at the selonoid at the back of the valve cover
    4. a drill bit to drill the whole
    5. a soldering iron and some solder
    all the rest as they say is history
  8. sensation
    sensation Junior Member
    Tap to vtec solenoid wire by the ecu. The wire is A4 and orange-white. A4 is in the long harness connector. Hook it LED to positive and ground.
