Vtec not working HELP
Discussion in 'HYBRID -> EG-EK / DC' started by civic32958, Oct 27, 2004.
  1. civic32958
    civic32958 Junior Member
    Florida
    I have a 95 EG hatch with a b16a2 swap. Had a turbo on it and it blow the bottom end. Ordered a new bottom end from a website, the guy said it was a b16a2 , everything fits and runs except rear motor mount is about 1 inch off.Double checked vtec wiring and manual powered up vtec sloneid and it works, also tryed another computer and it does not work. Now with everything on and running turbo too, everything works except the vtec. if someone could help maybe i got a b16a1 , and why doesnt the vtec work?? HELP
  2. pissedoffsol
    usdm 99-00 civic si = b16a2.
    most of the population are idiots and call the JDM b16a sir2 as it as well, but its, not. the rear mount on the civic si is not the same as the sir2.
    if you don't have vtec, check your oil pressure
  3. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    I have an JDM B16a Sir2 and used a 99-00 Si rear mount, and it worked fine... bolted up perfectly and my engine sits straight. BTW, it's in a 97 civic
