vtec oil pressure on b18c5
cee-j
hey hey!!!
I have 1991 sir and i just bought a b18c5 but where the vtec oil pressure switch is suppose to be there is none. Can i take the one off my b16a ????
there isn't one on jdm itr's. they don't use a vtec pressure switch.
usdms do use them though. and any b-series switch will work.
[post=417208]Quoted post[/post]​
Thats great thanks alot guys
Anymore helpful tip about my swap???
Just splice the VTM wire into the VTS wire and the ECU won't throw a CEL even without a pressure switch.
[post=421888]Quoted post[/post]​
Sorry i don't understand your short form.
Splice the pressure switch wire into ...what?
VTEC pressure switch into the VTEC solenoid wire. The ECU checks the VTEC oil pressure after VTEC engages, this mod tricks the ECU into thinking there is pressure on the VTEC oil pressure switch. FWIW, this works on OBDI ECUs, I don't know about OBDIIs, but I would imagine they would be similar.
