Vtec pistons in B18b block? need info please.
DuckSauce
I bought a Ek hatch with an unfinished swap. I was told the motor was running turbo before, which i believe since the oil lines where still connected and the oil pan was tapped. I just took the head off to change the head gasket and I come to find out that this block had the F.S.R. Honda B-series VTEC Pistons. Will this affect anything? I was told the motor was running a high compression turbo set-up with a Greddy drag kit. Any opinions on whether I keep the pistons in or swap them out?
ok cool. i appreciate the feed-back . Just wanted to make sure. Yeah im going to use a very experienced tuner. Im hoping to get some high numbers off this motor after a turbo is installed.
